Perform the following procedure to view the number of remaining virtual services resources on the switch.
- Select Virtual Service.
- Select the Globals tab.
Use data in the following table to use the Globals tab.
Name |
Description |
DiskRemain |
Shows the remaining disk space available, in Gigabytes (GB). |
NumCoresRemain |
Shows the remaining number of CPU cores available. |
MemSizeRemain |
Shows the remaining amount of memory size available, in Megabytes (MB). |
CopySourceFile |
Specifies the source file to copy. To specify a location, use the format: {VM_NAME_SRC}:{VM_FILE_PATH} or {NOS_FILE_PATH}. For example, figw:/home/rwa/configs/ipsec1.cfg identifies a file located in the VM. /intflash/ipsec1.cfg identifies a file located in the NOS. The valid path for a NOS location can be one of the following:
CopyDestinationFile |
Specifies the destination file to copy. To specify a location, use the format: {VM_NAME_DST}:{VM_FILE_PATH} or {NOS_FILE_PATH}. For example, figw:/home/rwa/configs/ipsec1.cfg identifies a file located in the VM. /intflash/ipsec1.cfg identifies a file located in the NOS. The valid path for a NOS location can be one of the following:
CopyAction |
Specifies an action to copy a file from source to destination. The switch supports the following action:
ScalarsName |
Specifies the virtual service name. You must specify the virtual service name if you use this tab to change the password or run a command. |
ExecuteCommand |
Specifies the Virtual Machine (VM) command to run. To include spaces in the syntax, include the text string in quotation marks ("). |
User |
Specifies the virtual service user name. The range is 0-20 characters. |
Password |
Specifies the virtual service password. |
FigwCli |
Specifies the command to send to the Fabric IPsec Gateway VM. For more information about Fabric IPsec Gateway commands, see Fabric Engine Command References. |
